Decoding bmp ?
antonius
Posted on April 11, 2014 at 11:21
Guys,
Does anyone of you have experience on decoding bmp ?
I want to display bmp file to my LCD...
Any clues ?
thanks
#i-have-a-clue
90 REPLIES 90
Posted on April 29, 2014 at 02:13
Pretty sure the printf() there isn't appropriate.
Yes, start by filling the panel with colour, and confirm those actually work, or if the colour is wrong.
Posted on April 29, 2014 at 02:17
Can you display white properly in your LCD ?
I will check tomorrow, but pretty sure it does.
Posted on April 29, 2014 at 03:03
The SSD1289 has a Transparency bit in Register 0x11, but it's application with respect to the data stream is not discussed further.
You could presumably do a test
if (rgb == 0xFFFF) rgb = 0xFFFE;
antonius
Posted on April 29, 2014 at 08:43
Like this :
              rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3);
              LCD_SetPoint(y/3, x/3, rgb);
I got no response, still dot dot white on the screen...
Posted on April 29, 2014 at 09:18
No like this, do you have no sense of logic and sequence?
rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3); // convert to colour space of display
if (rgb == 0xFFFF) rgb = 0xFFFE; // address transparent/white issue
LCD_SetPoint(y/3, x/3, rgb); // paint dot on screen
antonius
Posted on April 29, 2014 at 09:52
it's changing to FFFE but not in a solid LCD, there are some black spots on LCD...why is it ?
antonius
Posted on April 29, 2014 at 09:55
solid color with this :
if (rgb == 0xFFFF) rgb = 0xF7DE;
antonius
Posted on April 29, 2014 at 09:57
or
if (rgb == 0xFFFF) rgb = 0xFFFD; works allright..
Posted on April 29, 2014 at 21:07
You are asking me questions about a board and screen that I don't have, and cannot independently verify/test.
It is possible that x/3 or y/3 exceed the dimensions of the display.
Posted on April 29, 2014 at 23:08
The SSD1298 on the STM32F407 does appear to display the primary colours properly, and doesn't have issues with transparent/clear 0xFFFF. Painted the Blue/White flag without issue.
