Dear st team, I am using STM32F767BIT6 ,AND i had been used lessthen 1024 Flash memory. My question is , Can I use same programme code in STM32F767BGT6? please let me know if any changes required .
NJENN.1
I WANT to solder STM32F767BGT6 instead of STM32F767BIT6.
Same die more or less FLASH tested.
FW for smaller memory foot print will work in device with larger foot print.
Expect you'll actually want to test.
You can read the FLASH memory size, and adapt/check
Option Bytes might alter banking settings, watch you support full super-set of functionality if it impacts you.
