DAC DMA underrun interrupt on STM32F4-Discovery
‎2016-07-25 4:54 AM
Hi. I have problem with finding interrupt subroutine which Is called when DAC DMA underrun interrupt event happen. There isn't any DAC IRQ in which I can check status like this:
if(DAC_GetITStatus(DAC_Channel_1, DAC_IT_DMAUDR) == SET){ } thx for help, cheers.- Mark as New
‎2016-07-25 6:40 AM
Doesn't it just share TIM6_DAC_IRQHandler ? ; TIM6 and DAC1&2 underrun errors
‎2016-07-25 6:58 AM
Can I use this handler even when using other timer for DAC ?
‎2016-07-25 8:19 AM
Why would it matter? You need to enable the TIM6_DAC interrupt in the NVIC, enable the IT flags in the DAC, and filter/qualify the source of the interrupt in the handler. You won't see any TIM6 interrupts unless you enable them in the TIM.Up vote any posts that you find helpful, it shows what's working..
‎2016-07-25 9:03 AM
OK. For me it's quite strange that the same interrupt handler is used for two different peripherial.
Thx for help.
