copy 2 projects to my project, one is PWM, the other one is Examples\ADC
Linda
Posted on June 18, 2014 at 21:18
I copy 2 projects into mine, one is PWM, the other one is Examples\ADC\ADC_RegularConversion_DMA.  Both of them work perfectly separately
before, but after copied, only one can work.
I
guess it might because  some functions occurs 3 times, 1 in the Main(), 1 in PWM, 1 in ADC, like:  HAL_Init(); SystemClock_Config(); BSP_LED_Init(LED3);
I delete some, but the program still doesn’t work.
Please help.
Posted on June 18, 2014 at 21:55
Try using a Merge tool, and understand the differences in the projects, figure out the parts you need to take from each, and what you have to integrate.
Linda
Posted on June 18, 2014 at 22:49
what Merge tool I can use?
Posted on June 18, 2014 at 23:24
http://winmerge.org/
http://www.araxis.com/merge/index.en
