Connect a 8bit LCD to FSMC of STM32F103ZET6
CYuen.1
I've been trying to connect a 8-bit LCD to FSMC of STM32F103ZET6. But it seems not working at all. Even the display ID could not be retrieved. So that is a complete failure!
The LCD chip is ST7735S. This LCD works on other 8/16 bits mcu parallel interface.
I've set the fsmc data width to 8 bits.
Kindly help advising me anything I can do. Will other things like LCD BASE address are needed to be shifted somehow in 8-bit device?
Thank you very much!
0 REPLIES 0
