configure uart or swv (bluecoin) STEVAL-BCNKT01V1
Dinakaran Palani
hi everyone i am using an example audio loop example and planning to print the variable called pcm buffer on to console either swv or using the pins on the bluecoin station as uart pheripheral how should i implement this or worst case how to implement printf function on bluecoin
Andrew Neil
