2023-02-21 11:31 PM
I'm using DFSDM on NUCLEO-L476RG, the DFSDM configured as follows:
static void MX_DFSDM1_Init(void)
/* USER CODE BEGIN DFSDM1_Init 0 */
/* USER CODE END DFSDM1_Init 0 */
/* USER CODE BEGIN DFSDM1_Init 1 */
/* USER CODE END DFSDM1_Init 1 */
hdfsdm1_filter0.Instance = DFSDM1_Filter0;
hdfsdm1_filter0.Init.RegularParam.Trigger = DFSDM_FILTER_SW_TRIGGER;
hdfsdm1_filter0.Init.RegularParam.FastMode = DISABLE;
hdfsdm1_filter0.Init.RegularParam.DmaMode = ENABLE;
hdfsdm1_filter0.Init.FilterParam.SincOrder = DFSDM_FILTER_SINC2_ORDER;
hdfsdm1_filter0.Init.FilterParam.Oversampling = 500;
hdfsdm1_filter0.Init.FilterParam.IntOversampling = 100;
if (HAL_DFSDM_FilterInit(&hdfsdm1_filter0) != HAL_OK)
Error_Handler();
hdfsdm1_channel0.Instance = DFSDM1_Channel0;
hdfsdm1_channel0.Init.OutputClock.Activation = DISABLE;
hdfsdm1_channel0.Init.OutputClock.Selection = DFSDM_CHANNEL_OUTPUT_CLOCK_SYSTEM;
hdfsdm1_channel0.Init.OutputClock.Divider = 2;
hdfsdm1_channel0.Init.Input.Multiplexer = DFSDM_CHANNEL_EXTERNAL_INPUTS;
hdfsdm1_channel0.Init.Input.DataPacking = DFSDM_CHANNEL_STANDARD_MODE;
hdfsdm1_channel0.Init.Input.Pins = DFSDM_CHANNEL_SAME_CHANNEL_PINS;
hdfsdm1_channel0.Init.SerialInterface.Type = DFSDM_CHANNEL_SPI_FALLING;
hdfsdm1_channel0.Init.SerialInterface.SpiClock = DFSDM_CHANNEL_SPI_CLOCK_EXTERNAL;
hdfsdm1_channel0.Init.Awd.FilterOrder = DFSDM_CHANNEL_FASTSINC_ORDER;
hdfsdm1_channel0.Init.Awd.Oversampling = 1;
hdfsdm1_channel0.Init.Offset = 0;
hdfsdm1_channel0.Init.RightBitShift = 2;
if (HAL_DFSDM_ChannelInit(&hdfsdm1_channel0) != HAL_OK)
Error_Handler();
if (HAL_DFSDM_FilterConfigRegChannel(&hdfsdm1_filter0, DFSDM_CHANNEL_0, DFSDM_CONTINUOUS_CONV_ON) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN DFSDM1_Init 2 */
/* USER CODE END DFSDM1_Init 2 */
I need to change the filter and channel parameters based on some events (for evaluation, I'm using the blue button as that event).
from what i understand, the correct way to do so is:
I'm using the following code for that:
if (HAL_DFSDM_FilterRegularStop_DMA(&hdfsdm1_filter0) != HAL_OK)
Error_Handler();
while (HAL_DFSDM_ChannelGetState(&hdfsdm1_channel0) != HAL_DFSDM_CHANNEL_STATE_READY);
if (HAL_DFSDM_ChannelDeInit(&hdfsdm1_channel0) != HAL_OK)
Error_Handler();
if (HAL_DFSDM_FilterDeInit(&hdfsdm1_filter0) != HAL_OK)
Error_Handler();
hdfsdm1_filter0.Init.RegularParam.DmaMode = DISABLE;
if (ford==1)
hdfsdm1_filter0.Init.FilterParam.SincOrder = DFSDM_FILTER_SINC1_ORDER;
else if (ford==2)
else if (ford==3)
hdfsdm1_filter0.Init.FilterParam.SincOrder = DFSDM_FILTER_SINC3_ORDER;
else if (ford==4)
hdfsdm1_filter0.Init.FilterParam.SincOrder = DFSDM_FILTER_SINC4_ORDER;
else if (ford==5)
hdfsdm1_filter0.Init.FilterParam.SincOrder = DFSDM_FILTER_SINC5_ORDER;
hdfsdm1_filter0.Init.FilterParam.Oversampling = fosr;
hdfsdm1_filter0.Init.FilterParam.IntOversampling = iosr;
Error_Handler();
hdfsdm1_channel0.Init.RightBitShift = rShif;
Error_Handler();
Error_Handler();
if (HAL_DFSDM_FilterRegularStart_DMA(&hdfsdm1_filter0,dda, 10) != HAL_OK)
Error_Handler();
No matter what I try, ChannelDeInit returns HAL_ERROR.
During debugging, i've noticed that the channel instance changes with each interrupt, and then the ChannelDeInit doesn't "recognize" the channel.
Can you help please with how to solve this?
2023-03-05 1:42 AM
Can someone help with it please?
@Imen DAHMEN
