CC2520 and STM32
frank5
Posted on October 17, 2009 at 17:42
CC2520 and STM32
10 REPLIES 10
frank5
Posted on May 17, 2011 at 13:26
I am getting this week 2 CC2520 modules.
Searching the internet I haven't found something helpfull...
Has anyone had any expirience with the CC2520 using a STM32?
Any code example would be great.
Thank you.
kdeganck9
Dear,
I think if you search at TI for examples you should find something and maybe by just adjusting the hardware layer and compile it for STM32 it could work if written in C.
Maybe search also the older devices for examples.
Good luck
jj
As k.deganck says - we've used STM32 successfully with older CC1100 family.
Works well - you will likely be surprised by the role of software in distance and reliability enhancement.
frank5
CC1100 is quite different from the CC2520...
st3
My, my, this sounds remarkably familiar:
Has anyone had any expirience with the CC2520 using a C8051F3xx?
Thank you.
http://www.8052.com/forum/read/169651
frank5
So what?
I use STM32 and C8051F...!
If I used AVR I would also post also there...
if it's ok with you Mr. Sherlock!
st3
If you post on multiple forums, it is polite to say what you are doing, and provide links - so that people on one forum don't waste their time repeating what has already been said elsewhere!
st3
So you'll understand that the operation of the CC2520 modules is entirely independent of whatever processor you use - as stated:
http://www.8052.com/forum/read/169652
So what is it specifically about the STM32 that you want to know here?
pswenson
Did you use/port SimpliciTI?
