Cascaded Timer Causes Delay
Options
2014-10-03 7:14 AM
Posted on October 03, 2014 at 16:14
Using the STM32427, with TIM5 set up as a master to TIM1 and TIM8. This works fine; I get synchronous pulses like I expect. However, I'd also like to have TIM1 act as master for TIM4. When I enable TIM1 in master mode, it suddenly is no longer synchronous w/ TIM5/TIM8.
#stm32-timer
Labels:
- Labels:
TIM
Options
2014-10-03 7:43 AM
Posted on October 03, 2014 at 16:43
Hi
I thought I had answered you before..... ''When I enable TIM1 in master mode, it suddenly is no longer synchronous w/ TIM5/TIM8. '' I am not sure what happens if you cascade timers as masters ie TIM5 is master to TIM1 and TIM8 TIM1 is master to TIM4 Why do you not make TIM4 a slave to TIM5 as well (if that is possible - I am not sure)?
