Call a function before reseting by NRST
dmatheis
Posted on July 20, 2009 at 12:38
4 REPLIES 4
dmatheis
Posted on May 17, 2011 at 13:18
is it possible to call a function before the NRST-Pin resets the hole system (e.g. to save some data in an external eeprom)? Is there any IRQ-Handler which could be called when pressing the switch connected to my NRST-Pin?
Thank you :D
sofiene
Hi dmatheis;
You can use EXTI interrupt instead of NRST-Pin to reset the microcontroller.
How?
So you can connect a button in any EXTI. In the EXTI handler you can save your data and after that call NVIC_GenerateSystemReset() (software reset).
B.R.
M3allem
dmatheis
Hi M3allem,
thanks for your replay, but I'm searching for a solution to get the beheavior/functionality of the EXTI also on the NRST pin. :-]
swhite
A reset is a hardware condition that can't be trapped like a normal exception.
That said you can determine the cause of a reset *after* it has happened. See the ST Library function RCC_GetFlagStatus(). I do this in a current project to display/log the last reset cause along with additional information. Makes a great firmware/hardware debugging feature :)
Edit: You can (and I do) get indication of a power failure and do stuff *before* you reset.
[ This message was edited by: swhite on 20-07-2009 16:09 ]
