Bus Fault occured randomly during normal operation
edison72
Posted on November 01, 2012 at 07:44
Dear all,
MCU we are using is STM32 F103CBT6, on a motor driver application.
Wehave encountered a strange phenomenon that Bus Fault occurred randomly duringnormal operation, and the fault message shows that the PC we are getting arealso jumps randomly to invalid area.
We have turn off Prefetch buffer, and even reduce operation freq from 72Mhzdown to 36Mhz, the problem still exist.
does anyone ever seen this problem?
These are few of the random fault we are receiving:
Stack-R0 => 0x00000000
Stack-R1 => 0x00000000
Stack-R2 => 0x00000005
Stack-R3 => 0x00000000
Stack-R12 => 0x00000020
Stack-LR => 0x08011095
Stack-PC => 0x08010DF0
Stack-PSR => 0x61000000
SP Now => 0x200026E8
SP Startup => 0x20002708
HFSR => 0x00000000
CFSR => 0x00008200
    BFSR-PRECISERR = 1
    BFSR-BFARVALID = 1
    BFAR => 0x29014628
DFSR => 0x00000000
AFSR => 0x00000000
Stack-R0 => 0x20000065
Stack-R2 => 0x00000009
Stack-PC => 0x08010DEC
HFSR => 0x00000000
CFSR => 0x00008200
    BFSR-PRECISERR = 1
    BFSR-BFARVALID = 1
    BFAR => 0x000701D5
DFSR => 0x00000000
AFSR => 0x00000000
Stack-R2 => 0x00000031
HFSR => 0x00000000
CFSR => 0x00008200
    BFSR-PRECISERR = 1
    BFSR-BFARVALID = 1
    BFAR => 0x00060066
DFSR => 0x00000000
AFSR => 0x00000000
Stack-R0 => 0x40000000
Stack-R2 => 0x0000AAAA
Stack-R3 => 0x40003000
Stack-LR => 0x08010E01
Stack-PC => 0x08010E4A
Stack-PSR => 0x01000000
HFSR => 0x00000000
CFSR => 0x00000400
BFSR-IMPRECISERR = 1
DFSR => 0x00000000
AFSR => 0x00000000
Stack-R2 => 0x00000017
堆疊使ç�?¨æ•¸é‡� : 32 Byte
HFSR => 0x00000000
CFSR => 0x00008200
    BFSR-PRECISERR = 1
    BFSR-BFARVALID = 1
    BFAR => 0x001E018D
DFSR => 0x00000000
AFSR => 0x00000000
Posted on November 01, 2012 at 12:48
Seems some consistency in SP and LR at the failure point. Are you reporting the application stack? What subroutine is being called by the code immediately prior to LR?
You should confirm your stack is big enough, check for things which could overrun the stack variables, or DMA/IRQ which might be modifying the stack content.
Make your user stack twice as big, put a fill pattern in there, and gauge maximal usage.
