Gasson.Gary
BlueNRG-1 DIO11
  • June 17, 2018
  • 0 replies
  • 386 views
Posted on June 17, 2018 at 12:34
I used the BlueNrg-1 on a few projects but I have never had the problem before as I have never used DIO11. What concerns me that every is 100% when stepping through my code just before entering the BlueNRG_Sleep function.
DIO11 is low as it should be but once I enter sleep mode then DIO11 goes high.
This is causing my power consumption to be higher as required.
Please can some advice if I am doing anything wrong?
