Binary representation in IAR
relaxe
Posted on January 07, 2009 at 10:20
5 REPLIES 5
relaxe
Posted on May 17, 2011 at 12:58
Using IAR 5.20:
Normal representation of:
Decimal:
i = 30;
Hex:
i = 0x1E;
How do you write binary variables????
Binary:
i = ?????????????????????
Please!
-Relaxe
paulsmitton9
You can use a macro. See:
http://cprog.tomsweb.net/binconst.txt
picguy
In the assembler use 01010b and the like
In C/C++ I found nothing in the docs. Given that plus what I tried you may need to use standard C/C++ hex 0xABC or octal 0123.
st3
The standard 'C' programming language provides no way to write binary constants.
If IAR have provided some extension to allow this, then it will be in their Documentaion - but this is quite uncommon. :(
Given that anything you might find is totally non-standard and, therefore, totally non-portable, I suggest that you just stick to Hex.
stevemelnikoff9
Some compilers allow binary data to be represented by starting the value with ''0b'', e.g.: 0b00000000.
Steve.
