2008-11-12 03:53 AM
Anybody have a code for SDHC over SDIO?
2011-05-17 03:52 AM
I've been working with the sdcard demo code for reading/writing to the SDcard. However, this code does not seem to handle SDHCs.
Do someone have a code/module ready to R/W SDHC with the high-density devices SDIO? Thanks!2011-05-17 03:52 AM
Dear Relaxe,
You can refer this demo from SThttp://www.st.com/stonline/products/support/micro/files/um0549.zip
there is a Mass storage example that supports SDHC SDIO memory cards, I have tested 2 SD cards SDHC more than 4Gbytes ( Sandisk and Verbatim) and working fine. Hope this helps you. Cheers, STOne-32.2011-05-17 03:52 AM
STOne-32-
This is good news - thank you. Do you know if Micro SDHC - by same makers you specified - will also work? Regards, jj2011-05-17 03:52 AM
Dear jj,
Ye, Indeed ! I'm referring to micro SD... Sorry my limited details :-) Cheers, ST {1+3=2} :-)
