AES-CBC(128 bit) Encryption for STM32H750VB IC
nanotronicsnss
I am using STM32h750VB for a Project. I need to use AES -CBC Mode of Encryption.I have downloaded the cube-cryptolib and when I searched for the crypto code of my IC, I found that the AES CBC code is available for STM32H743ZI-Nucleo..Can i use the same for my IC to perform AES-CBC 128 bit encryption and decryption?
The H753ZI has the CRYP enabled, the H743ZI does not. The H750VB is basically the same die, code for the other boards should port with little effort.
Dupe https://community.st.com/s/question/0D53W000004mJRhSAM/crypto-lib-for-stm32h750
