About I2C
s1170198
Posted on December 06, 2012 at 11:27
Hi
I use STBee.
When I perform I2C in Arduino, I write such a code.
void writeDevice(byte address, byte registerAddress, byte data){
  Wire.beginTransmission(address);
  Wire.write(registerAddress);
  Wire.write(data);
  Wire.endTransmission();
byte readDevice(byte address, byte registerAddress){
  byte data = 0;
  Wire.requestFrom((char)address,1);
  if(Wire.available()){
    data = Wire.read();
  return data;
There is a question about a function of Wire.requestFrom of this cord.
It is a function to require 1 byte to a device.
When I want to use this function in STBee, how should I do it?
s1170198
Posted on December 06, 2012 at 11:52
I2C communicates with an acceleration sensor(ADXL345).
