STEVAl-CTM006V1 motor profiling.
‎2024-02-05 2:15 AM
please advice with the issue of motor profiling.
mcsdk: 6.2.1
control board: nucleo-g474re
Bridge: XNUCLEO-IHM09M2
Power Board: STEVAL-CTM009V1
Motor: Motenergy ME1304
How can I run motor profiler for this setup?
MC Workbench does not allow to generate FW for motor profiler.
Best regards, Taras.
‎2024-02-05 5:29 AM
Hello @tasifacij ,
Unfortunately, the profiler FW supports only 3-shunt topology. It is why MC Workbench prevents you to generate your project.
The best advice I can give you is to enter your motor characteristics manually following this user guide :
How To manually configure the motor parameters - stm32mcu
Cedric
‎2024-02-05 5:29 AM
Hello @tasifacij ,
Cedric
‎2024-02-05 5:38 AM
Appreciate
