2021-08-12 6:26 AM
I have a control board with the MCU F302R8, and a power board with the ST L6230. For my tests, I want to shift the motor phase voltages, so that the phase shift offset is not 120 degrees, and I want to be able to change the offset manually. My question is: is this actually possible with the ST L6230? Or shall I look for another motor driver?
2021-09-05 3:10 AM
Dear @MDe L.3
Could you say us more about your SW setup?
Do you use STM32 MC-SDK tools suite?
Best regards
