Motor startup failure
Fkadr.1
I have purchased stspin32f0602 evaluation boad and I am not able to spin my motor every time I try spinning the motor it says startup failure.
I have tried everything in your FAQ pdf.
Please let me download the software.
My motor parameter are
Resistance-1.6 ohm
Inductance- 2.8mh
Back emf constant is 33.5
Please help me out
Hi
I tried few things and was able to spin my motor
I changed the advanced startup parameter vale and switching rate and was able to get good results.
Thanks ​ for your reply
4 REPLIES 4
Laurent Ca...
Lead II
Dear @Fkadr.1​
Welcome to the STM32 Community
Could you give to the STM32 Community the link to the PDF you wrote about?
Best regards
Cristiana SCARAMEL
Hello @Fkadr.1​ ,
in addition to the file requested by Laurent, could you share more details on your application?
  • Target ratings
  • which algorithm you want to drive the motor
Let us know more details for a better support.
If you feel a post has answered your question, please click "Accept as Solution"
Hi
Hi,​
What Kind changes you have done in advanced startup ?​
Means Depends which Factors?​
Karan​
