Motor Pilot RegDesc cannot input float data
Options
‎2024-05-22 9:41 PM
I added a custom REG in Motor Pilot and edited the MC_FOC_SDK.qml file, which allows usage, but I can only input integers, not floating-point data. Here is the configuration information.
RegListSTMV2.json
"Id" : 162,
"Name" : "OVER_BUS_CURRENT",
"Description" : "max bus current",
"Type" : "F32",
"Unit" : "A",
"Scope": "Motor",
"Access" : "RW",
"UpdateFrequency": "MediumFreq"
MC_FOC_SDK.qml
McRegGroupSpinBox {
RegDesc {
regName: "OVER_BUS_CURRENT"
decimals:1
label: "max ibus"
to: 500
stepSize: 1
tooltip:"(0-500)"
RegDesc {
decimals:1
label: "max ibus"
to: 500
stepSize: 1
tooltip:"(0-500)"
Options
‎2024-05-23 12:43 AM
Hello honkerz,
RegDesc is supporting integer only
You can use McRegSpinBoxFloat for float value
BRs
If you agree with my answer, please accept it by clicking on 'Accept as solution'.
1 REPLY 1
Options
Hello honkerz,
BRs
