2024-05-31 8:45 AM
Hello, I have following problem:
I generated a project using MC Workbench (6.3) and everything works with Motor Pilot (1.2.9). For debugging I would like to have a serial output over the same USART as the motor pilot. For start just print "Hello World!" every second inside the main loop.
printf: does not work
HAL_UART_Transmit: works sometime for 1-2 messages
HAL_UART_Transmit_DMA: does not work.
Is there a simple way to send custom (maybe through MCP)?
Best regards
