hsg.1440
I would like to know the physical concept of a specific item.
  • July 17, 2024
  • 0 replies
  • 773 views
Currently using ST MOTOR WORKBENCH 5.4.8.
   About the numbers in the square area in the picture below
- It appears to be a converted number rather than the flowing current value. I would like to know the exact meaning of this number.
- For example, if you get 10000, you can actually interpret it as 4A. Like this
This is the speed measurement part. We are currently using the sensorless (Observer + PLL) method.
1) I am curious about the exact physical meaning of Observer's G1 and G2 in the black square.
2) I would like to know what actual changes occur when the P/I value of the PLL in the red square changes.
thanks.
