2025-11-12 6:32 PM - last edited on 2025-11-12 11:00 PM by Peter BENSCH
Hello! I saw in the release notes for MCSDK 6.4.0 that there is an "Added new Maximum Modulation Index (MMI) computation compatible for all sensor-less or sensor algorithms." How should I use overmodulation on the HSO?
2025-11-12 11:24 PM
Hello @WJHuang,
Refer to the Circle limitation chapter of the User Manual documentation available through Workbench tool > About > Documentations > Documentation > User manual tab for the description of the Maximum Modulation Index.
The over-modulation feature is not available with HSO speed sensing.
2025-11-27 10:18 PM
Thank you!When will HSO speed sensing support overmodulation?
