Laurent Ca...
Senior III
Jun 28, 2021 2:48 AM UTC
Dear @cewqss​
I don't think your question is related to STM32 Motor Control Topic, is it?
Can I/you edit topics?
Best regards
mattias norlander
Jun 28, 2021 12:43 PM UTC
Hi @cewqss​,
ST has an initiative called STM32duino. Personally I don't know much about it, nor about the AdaFruit provided libraries you are trying to use and their dependencies. So I don't know "how deep the rabbit hole goes".
In STM32 world, you could also try the alternative approach of using CubeMX to configure the required peripherals to do what is needed. But you need to study the Arduino code and libraries and also the STM32 peripherals. I don't see an easy turn-key solution.
mattias norlander
Jun 28, 2021 2:40 PM UTC
Maybe you can also have a look here if you want to go the STM32Cube way:
https://wiki.st.com/stm32mcu/wiki/STM32StepByStep:STM32_Advance_MotorControl
