Encoder Alignment
sdavo.1
"Should the encoder alignment be done after every microcontroller reset? Is there a way to do it once, save it in memory, and then load it at every startup? I can’t move the motor every time for encoder alignment, and when my system turns on, it must work immediately without moving for alignment."
0 REPLIES 0
