2024-05-30 1:53 AM - last edited on 2024-05-30 2:33 AM by Peter BENSCH
Hey all, i believe i've found a mistake on the stspin32f0601 datasheet.
https://www.st.com/en/motor-drivers/stspin32f0601.html
Page 12, RON_OD, Units are in Watts instead of Ohm, I believe this is supposed to be the value of RON_OD.
Thank you
2024-06-02 10:11 PM
Hello @kevinganhito , @Peter BENSCH ,
Thanks for sharing this! I will inform a respective team to have a look into this.
Lina
2024-05-30 2:41 AM
Welcome @kevinganhito, to the community!
Very well spotted, thank you for the information!
The internal preliminary data sheet still had the Greek character Ω for Ohm there, but unfortunately at least in revision 4 it contains W. This was probably caused by reformatting the section, because W is the equivalent for the Ω in the normal character set.
/Peter
2024-06-02 10:11 PM
Lina
