2022-07-12 2:49 AM
I am using zephyr rtos for my application. I am running basic Blinky example on ST boards. I am able to build and flash that examples on nucleo_h743zi board. however same example am trying to run on nucleo_f439zi board. Here am getting "Invalid Board" error.
CMake Error at D:/zephyrproject/zephyr/cmake/modules/boards.cmake:154 (message):
Invalid BOARD; see above.This error message am getting. above this msg we have list of supported board , i didn't find the nucleo_f439zi board in the list . so am bit confused do we have zephyr support on that particular board. or am I missing something. Kindly help me to solve this out.
Note-
I am using windows system and west tool to build and flash code.
2022-07-27 5:17 AM
Nucleo F439ZI is not yet supported in Zephyr RTOS.
You can find the list of bards available here:
2022-07-27 7:35 AM
You should at least recommend NUCLEO-F429ZI:
https://docs.zephyrproject.org/latest/boards/arm/nucleo_f429zi/doc/index.html
The only difference is a crypto/hash peripheral not being available.
