X CUBE USB AUDIO not recognized as audio device
2024-03-05 10:27 PM
I want to use X CUBE USB AUDIO examples in X CUBE IDE.
After generating the binary code (without errors) and flashing the binary code via DFU, the card is not recognized as an audio device, I tried on all 4 projects. I unplugged USB, do reset, nothink change.
On the other hand, if I generate for example the binary of another audio project: FP-AUD-SMARTMIC1, and flash it via DFU, the card is recognized as an audio device.
Thanks by advance.
Audio and voice
2024-04-19 1:12 AM
Hi @Loulou
You can change your target in the compiler. The only difference is RE with less pin count.
Please consider opening new discussion for further questions.
- « Previous
- 1
- 2
- Next »
