usb using in stm32h743zi
SITARAM
when i connected usb connector in stm32h743zi,  that time what function working usb connector and if i remove usb connector then what function going to usb connector ,give me that function i remove usb
AScha.3
I suppose from your writing, you want to know, how to get the info: usb no more connected ...?
Look/search for : APPLICATION_DISCONNECT , then do ...whatever you want to ->
if (Appli_state == APPLICATION_DISCONNECT) .....
FBL
Hello @SITARAM
You may need to develop more your question. In my understanding, you may have asked about the USB device states : Attached, powered, configured .. Check the user manual UM1734_STM32Cube.book to learn more.
Best regards,
FBL
