USB_OTG_FS registers similar to USB_OTG_HS ?
ColaChugger
hi,
I want to use USB-FS. For initialisation I used the tool integrated in the cube IDE. The RM contains the HS-registers but not the FS-registers. Since the tool changes bits that are not supposed to be changed (namely: GOTGCTL) I assume the registers are not similar.
The example:
GOTGCTL reset value: 0x0001 0000
GOTGCTL changable values according to RM p.2628 0x003F 1FFF
GOTGCTL values after the tool init: 0x0321 0000
Now I wonder where I find the info about the FS registers.
cheers
0 REPLIES 0
