USB Host and Composite device..
mak1308
Posted on February 08, 2016 at 12:03
How to make on STM32F4 USB a host with support of the Composite device?
I made the project in CubeMX, but in this project there is a support of different classes of devices, but there is no support of the Composite device.
#host #usb
10 REPLIES 10
Walid FTITI_O
Senior II
Posted on February 09, 2016 at 11:56
Hi g.marat,
Could you specify which version of CubeMx you are using ?
-Hannibal-
mak1308
Posted on February 09, 2016 at 13:18
Version 4.12.0
Walid FTITI_O
Senior II
Posted on March 10, 2016 at 18:57
Hi g.marat,
Try the new version 4.13.0
-Hannibal-
tsuneo
Posted on March 11, 2016 at 14:23
Regardless of CubeMX version,
STM32_USB_Host_Library V3.2.2 / 07-July-2015 (included in the latest STM32Cube_FW_F4_V1.11.0) doesn't support composite device yet.
It is obvious when you see this code in usbh_core.c
USBH_StatusTypeDef  USBH_Process(USBH_HandleTypeDef *phost)
  switch (phost->gState)
  case HOST_CHECK_CLASS:
    if(phost->ClassNumber == 0)
      USBH_UsrLog (''No Class has been registered.'');
    else
      phost->pActiveClass = NULL;
      for (idx = 0; idx < USBH_MAX_NUM_SUPPORTED_CLASS ; idx ++)
        if(phost->pClass[idx]->ClassCode == phost->device.CfgDesc.Itf_Desc[0].bInterfaceClass)  // <----
          phost->pActiveClass = phost->pClass[idx];
Just the first interface (Itf_Desc[0]) is hard-coded, here.
To support a composite device,
''case HOST_CHECK_CLASS:'',''case HOST_CLASS_REQUEST:'', and ''case HOST_CLASS:'' should be modified so that these cases do their job for each interface.
Tsuneo
Posted on January 19, 2017 at 08:12
Hi, i'm trying to do the similar thing to g.marat.
I used stm32f4 discovery board to communicate with Dualshock4 (PS4's controller) which has 4 interface (bNumInterfaces) but there are 6
element
s in the Itf_Desc[] array.
After i connected then read the CfgDesc i found that only Itf_Desc[5] is HID class. So now i'm trying to communicate with that interface.
Here is what i had done:
in case HOST_CHECK_CLASS: hard-coded Itf_Desc[5]
in function: USBH_HID_InterfaceInit, i set phost->Control.pipe_in=HID_Handle->InPipe and phost->Control.pipe_out = HID_Handle->OutPipe .
but then i got stuck at USBH_HID_GetHIDDescriptor because USBH_HandleEnum 's state is USBH_BUSY and URB_Status is USBH_URB_NOTREADY.
hope you could help my case.
Posted on January 19, 2017 at 17:06
element
It sounds odd.
I don't have Dualshock 4. I've searched for its descriptors on the net, found them on these sites.
http://www.psdevwiki.com/ps4/DS4-USB
http://eleccelerator.com/wiki/index.php?title=DualShock_4
According to these sites, Dualshock 4 exposes just single HID interface.
A couple of more sites also show the same descriptors.
Once on your PC, read out the descriptors of your Dualshock4.
You may have a variant of Dualshock4 😉
Here are utilities for each OS,
Windows - USBView
http://www.ftdichip.com/Support/Utilities.htm ♯ MicrosoftUSBView
Linux - lsusb command
MacOSX - USBProber
http://superuser.com/questions/781982/how-can-i-install-usb-prober-from-the-developer-sdk-on-mac-os-x
If your Dualshock4 would be the standard one (single HID I/F), you may start with HID host example, generated by CubeMX.
Tsuneo
Posted on January 20, 2017 at 05:29
First of all, thanks you for your time
yep , i had already read those site few days ago but their information is for old Dualshock 4 (CUH-ZCT1) , mine is CUH-ZCT2  and i cant find any site show this version's descriptors.
the PID of CUH-ZCT2 is 0x09CC when CUH-ZCT1 is 0x05C4
I had successfully read my keyboard and mouse with HID host generated by CubeMX.
I have just tested with my friend's Dualshock 3 which have 1 interface, and it had gone further
Here is the descriptor i get when use USBView :
Device Descriptor:
bcdUSB: 0x0200
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 (64)
idVendor: 0x054C (Sony Corporation)
idProduct: 0x09CC
bcdDevice: 0x0100
iManufacturer: 0x01
0x0409: 'Sony Interactive Entertainment'
iProduct: 0x02
0x0409: 'Wireless Controller'
iSerialNumber: 0x00
bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x01
Device Bus Speed: Full
Device Address: 0x0A
Open Pipes: 2
Endpoint Descriptor:
bEndpointAddress: 0x84 IN
Transfer Type: Interrupt
wMaxPacketSize: 0x0040 (64)
bInterval: 0x05
bEndpointAddress: 0x03 OUT
bInterval: 0x05
Configuration Descriptor:
wTotalLength: 0x00E1
bNumInterfaces: 0x04
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0xC0 (Bus Powered Self Powered )
MaxPower: 0xFA (500 Ma)
Interface Descriptor:
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x00
bInterfaceClass: 0x01 (Audio)
bInterfaceSubClass: 0x01 (Audio Control)
bInterfaceProtocol: 0x00
iInterface: 0x00
Audio Control Interface Header Descriptor:
bLength: 0x0A
bDescriptorType: 0x24
bDescriptorSubtype: 0x01
bcdADC: 0x0100
wTotalLength: 0x0047
bInCollection: 0x02
baInterfaceNr[1]: 0x01
baInterfaceNr[2]: 0x02
Audio Control Input Terminal Descriptor:
bLength: 0x0C
bDescriptorSubtype: 0x02
bTerminalID: 0x01
wTerminalType: 0x0101 (USB streaming)
bAssocTerminal: 0x06
bNrChannels: 0x02
wChannelConfig: 0x0003
iChannelNames: 0x00
iTerminal: 0x00
Audio Control Feature Unit Descriptor:
bLength: 0x0A
bDescriptorSubtype: 0x06
bUnitID: 0x02
bSourceID: 0x01
bControlSize: 0x01
bmaControls[0]:
03
bmaControls[1]:
00
bmaControls[2]:
00
iFeature: 0x00
Audio Control Output Terminal Descriptor:
bLength: 0x09
bDescriptorSubtype: 0x03
bTerminalID: 0x03
wTerminalType: 0x0402 (Headset)
bAssocTerminal: 0x04
bSoruceID: 0x02
iTerminal: 0x00
bLength: 0x0C
bTerminalID: 0x04
bAssocTerminal: 0x03
bNrChannels: 0x01
wChannelConfig: 0x0000
iChannelNames: 0x00
iTerminal: 0x00
bLength: 0x09
bUnitID: 0x05
bSourceID: 0x04
bControlSize: 0x01
bmaControls[0]:
03
bmaControls[1]:
00
iFeature: 0x00
bLength: 0x09
bTerminalID: 0x06
bAssocTerminal: 0x01
bSoruceID: 0x05
iTerminal: 0x00
bInterfaceNumber: 0x01
bNumEndpoints: 0x00
bInterfaceSubClass: 0x02 (Audio Streaming)
iInterface: 0x00
bAlternateSetting: 0x01
bNumEndpoints: 0x01
iInterface: 0x00
Audio Streaming Class Specific Interface Descriptor:
bLength: 0x07
bTerminalLink: 0x01
bDelay: 0x01
wFormatTag: 0x0001 (PCM)
Audio Streaming Format Type Descriptor:
bLength: 0x0B
bFormatType: 0x01
bNrChannels: 0x02
bSubframeSize: 0x02
bBitResolution: 0x10
bSamFreqType: 0x01
tSamFreq[1]: 0x007D00 (32000 Hz)
bEndpointAddress: 0x01 OUT
Transfer Type: Isochronous
wMaxPacketSize: 0x0084 (132)
wInterval: 0x0001
bSyncAddress: 0x00
Audio Streaming Class Specific Audio Data Endpoint Descriptor:
bLength: 0x07
bDescriptorType: 0x25
bmAttributes: 0x00
bLockDelayUnits: 0x00
wLockDelay: 0x0000
bInterfaceNumber: 0x02
bNumEndpoints: 0x00
iInterface: 0x00
bNumEndpoints: 0x01
iInterface: 0x00
bLength: 0x07
bTerminalLink: 0x06
bDelay: 0x01
bLength: 0x0B
bFormatType: 0x01
bNrChannels: 0x01
bSubframeSize: 0x02
bSamFreqType: 0x01
tSamFreq[1]: 0x003E80 (16000 Hz)
bEndpointAddress: 0x82 IN
wMaxPacketSize: 0x0022 (34)
wInterval: 0x0001
bSyncAddress: 0x00
bLength: 0x07
bmAttributes: 0x00
wLockDelay: 0x0000
bInterfaceNumber: 0x03
bNumEndpoints: 0x02
bInterfaceClass: 0x03 (HID)
bInterfaceSubClass: 0x00
iInterface: 0x00
HID Descriptor:
bcdHID: 0x0111
bCountryCode: 0x00
bNumDescriptors: 0x01
bDescriptorType: 0x22
wDescriptorLength: 0x01FB
bInterval: 0x05
bInterval: 0x05
And it's similar which the one i got by stm32f4.
Posted on January 20, 2017 at 14:36
Liêm Lê wrote:
mine is CUH-ZCT2 (Dualshock 4 ver2)
OK, your USB device is a composite device of four interfaces,
0 Audio Control 1 Audio Streaming (OUT) 2 Audio Streaming (IN) 3 HID
You may still start at a USBHID host generated by CubeMX.
CubeMX: v4.0 CubeF4: v1.0
The Cube HID host is customized for boot mouse and keyboard.
A little modification will release this limitation. Here is the snippet.
As your device has four interfaces, this macro should be touched to accept more interfaces than the default.
usbh_conf.h
// line 56:
#define USBH_MAX_NUM_INTERFACES 2 <--- 4
To accept the HID interface of DS4, USBH_HID_InterfaceInit is modified.
usbh_hid.c
static USBH_StatusTypeDef USBH_HID_InterfaceInit (USBH_HandleTypeDef *phost)
// replace line 147
// interface = USBH_FindInterface(phost, phost->pActiveClass->ClassCode, HID_BOOT_CODE, 0xFF);
 interface = USBH_FindInterface(phost, phost->pActiveClass->ClassCode, 0x00, 0x00);
// delete from line 161 to 176
 /*Decode Bootclass Protocol: Mouse or Keyboard*/
 if(phost->device.CfgDesc.Itf_Desc[phost->device.current_interface].bInterfaceProtocol == HID_KEYBRD_BOOT_CODE)
 USBH_UsrLog ('KeyBoard device found!');
 HID_Handle->Init = USBH_HID_KeybdInit;
 else if(phost->device.CfgDesc.Itf_Desc[phost->device.current_interface].bInterfaceProtocol == HID_MOUSE_BOOT_CODE)
 USBH_UsrLog ('Mouse device found!');
 HID_Handle->Init = USBH_HID_MouseInit;
 else
 USBH_UsrLog ('Protocol not supported.');
 return USBH_FAIL;
// add this line, instead
 HID_Handle->Init = USBH_HID_MouseInit; // replace with USBH_HID_DS4Init, after DS4 handler is established
Now that, the modified host code catches the HID interface of the DS4.
As the next steps,
1) Read out the report descriptor from your DS4 2) Identify report fields for DS4 axes, buttons, hat switches and specific functions
The report descriptor defines the size of reports and their fields for input/output/feature reports (data block). It also gives suggestions of field type (Axis, button, hat switch). But just with the report descriptor, each data field can't be identified. You'll identify each field by finding the field whose value changes when you would manipulate each axis/botton.
There are a couple way to read out the report descriptor, here is easier one 😉
0. Download the trial (33 days) of USBlyzer
http://www.usblyzer.com/download.htm
1. Run USBlyzer. Under Capture menu, confirm that 'Capture Hot-plugged' has check mark. If not, select it once. 2. push 'Start Capture' button 3. Plug in your DS4 to the PC. - USBlyzer starts to log the traffic 4. After 3-4 seconds, push 'Stop Capture' button 5. On the Device Tree pane, find the target and click 'USB Human Interface Device' just above the target. - USB Properties pane shows the descriptors of the mouse with HID report descriptor. 6. Right click on USB Properties pane, and choose 'Export' on the right menu. - file dialog saves a HTML file of descriptors.
Please post the descriptors HTML file, here.
We'll analyze the report descriptor, together.
Tsuneo
Posted on January 21, 2017 at 13:27
Hi Tsuneo,
As i mentioned before even the cfgDesc said it has 4 interface (bNumInterfaces) but there is 6 elements Itf_Desc[] array. so the USBH_MAX_NUM_INTERFACES should be 6.(i attached an image).
And i had done the same thing you said about
USBH_HID_InterfaceInit() function. Not just that, the USBH_SelectInterface (phost, interface) need to be modified too.
USBH_StatusTypeDef USBH_SelectInterface(USBH_HandleTypeDef *phost, uint8_t interface) {  USBH_StatusTypeDef status = USBH_OK;   // if(interface < phost->device.CfgDesc.bNumInterfaces) // {  phost->device.current_interface = interface;  USBH_UsrLog ('Switching to Interface (#%d)', interface);  USBH_UsrLog ('Class : %xh', phost->device.CfgDesc.Itf_Desc[interface].bInterfaceClass );  USBH_UsrLog ('SubClass : %xh', phost->device.CfgDesc.Itf_Desc[interface].bInterfaceSubClass );  USBH_UsrLog ('Protocol : %xh', phost->device.CfgDesc.Itf_Desc[interface].bInterfaceProtocol );  // } // else // { // USBH_ErrLog ('Cannot Select This Interface.'); // status = USBH_FAIL;  // }  return status;  }�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
Because
USBH_FindInterface(phost, phost->pActiveClass->ClassCode, 0x00, 0x00); returned 5 but phost->device.CfgDesc.bNumInterfaces just only 4.
I have a question about opening pipe too. Why they not set phost->Control.pipe_out/in after opened it
for ( ;num < max_ep; num++)  {  if(phost->device.CfgDesc.Itf_Desc[phost->device.current_interface].Ep_Desc[num].bEndpointAddress & 0x80)  {  HID_Handle->InEp = (phost->device.CfgDesc.Itf_Desc[phost->device.current_interface].Ep_Desc[num].bEndpointAddress);  HID_Handle->InPipe =\  USBH_AllocPipe(phost, HID_Handle->InEp);    /* Open pipe for IN endpoint */  USBH_OpenPipe (phost,  HID_Handle->InPipe,  HID_Handle->InEp,  phost->device.address,  phost->device.speed,  USB_EP_TYPE_INTR,  HID_Handle->length);     //phost->Control.pipe_in=HID_Handle->InPipe;  USBH_LL_SetToggle (phost, HID_Handle->InPipe, 0);    }  else  {  HID_Handle->OutEp = (phost->device.CfgDesc.Itf_Desc[phost->device.current_interface].Ep_Desc[num].bEndpointAddress);  HID_Handle->OutPipe =\  USBH_AllocPipe(phost, HID_Handle->OutEp);    /* Open pipe for OUT endpoint */  USBH_OpenPipe (phost,  HID_Handle->OutPipe,  HID_Handle->OutEp,   phost->device.address,  phost->device.speed,  USB_EP_TYPE_INTR,  HID_Handle->length);     //phost->Control.pipe_out=HID_Handle->OutPipe;  USBH_LL_SetToggle (phost, HID_Handle->OutPipe, 0);     }    } �?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
After i done all of those i still got stuck at USBH_HID_ClassRequest() in case HID_REQ_GET_HID_DESC:
case HID_REQ_GET_HID_DESC:    /* Get HID Desc */     if (USBH_HID_GetHIDDescriptor (phost, USB_HID_DESC_SIZE)== USBH_OK)  {  USBH_HID_ParseHIDDesc(&HID_Handle->HID_Desc, phost->device.Data);  HID_Handle->ctl_state = HID_REQ_GET_REPORT_DESC;  }    break;�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
USBH_HID_GetHIDDescriptor can't return USBH_OK.
USBH_HID_SetProtocol (phost, 0) in 'case HID_REQ_SET_PROTOCOL:' got the same problem too.
So i bypassed those then get into USBH_HID_Process() but it stuck in 'case HID_IDLE:' too.
case HID_IDLE:  if(USBH_HID_GetReport (phost,  0x01,  0,  HID_Handle->pData,  HID_Handle->length) == USBH_OK)  {    fifo_write(&HID_Handle->fifo, HID_Handle->pData, HID_Handle->length);   HID_Handle->state = HID_SYNC;  }    break;�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
i wish that it could be easy as said 😉
Do you have or know where i can get some documents about USB host, i did some search but only got 2 site :
http://www.beyondlogic.org/usbnutshell/usb6.shtml#StandardDeviceRequests
http://www.usbmadesimple.co.uk/ums_5.htm
and both of those don't explain about parameters of USB HID Request.
i couldn't get the meanning of wValue and wIndex in this function:
USBH_StatusTypeDef USBH_HID_GetReport (USBH_HandleTypeDef *phost,  uint8_t reportType,  uint8_t reportId,  uint8_t* reportBuff,  uint8_t reportLen) {    phost->Control.setup.b.bmRequestType = USB_D2H | USB_REQ_RECIPIENT_INTERFACE |\  USB_REQ_TYPE_CLASS;      phost->Control.setup.b.bRequest = USB_HID_GET_REPORT;  phost->Control.setup.b.wValue.w = (reportType << 8 ) | reportId;    phost->Control.setup.b.wIndex.w = 0;  phost->Control.setup.b.wLength.w = reportLen;    return USBH_CtlReq(phost, reportBuff , reportLen ); }�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?�?
________________
Attachments :
debug.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hyyk&d=%2Fa%2F0X0000000bEo%2FMj53S8USgoKRhQ7pbWjga5ZaZIdmAueJL9P6yHWw27M&asPdf=false
