USB connection ends with TXERR
Emmil
Posted on September 23, 2015 at 21:04
Hi there forum,
I would like to connect a USB pen to my STM32F4-Discovery kit.
I am using libraries from stsw-stm32068.zip, and the GPIO, USB initialization code and the usb_conf.h and usbh_conf.h files are from Audio_playback_and_record example.
After connecting a USB disk to the system the host state machine idles in HOST_CTRL_XFER, polling the USB state, which is always URB_IDLE.
Looking at the corresponding host channel interrupt register, I see, that TXERR flag has been set, which according the documentation can mean:
  • CRC check failure
  • Timeout
  • Bit stuff error
  • False EOP
The USB disk works on my computer and the cable I am using is working as expected, too.
Can anyone give me few pointers where to look for solutions?
Thanks.
#stm32 #usb #discovery #device
2 REPLIES 2
Emmil
Posted on November 22, 2015 at 20:22
Anyone?
Emmil
Posted on November 23, 2015 at 18:37
OK, I have a clue.
I have found two different versions of system_stm32f4xx.c.
One version of the file never works with USB, the other one works mostly (depending on used USB disk), but eventually also dies on TXERR.
Diffing them I see different values for PLL, however I am a SSE (Simple Software Engineer) and I really don't understand the impact of the settings.
Can those values be fine tuned so the USB will work always?
Update:
The forum seems to be broken and I can't upload the mentioned files, so here are at least the values:
Works:
HSE Frequency (HZ) = 8000000
PLL_M = 8
High Performance Mode = Enabled
Broken:
HSE Freqency (HZ) = 25000000
PLL_M = 25
Main regulator output mode voltage = Scale 1 mode
