2019-01-08 11:56 PM
There is a bug in stm32f7xx_hal_i2c.c!!!!!!!!!!!
static HAL_StatusTypeDef I2C_Disable_IRQ(I2C_HandleTypeDef *hi2c, uint16_t InterruptRequest)
uint32_t tmpisr = 0U;
if ((InterruptRequest & I2C_XFER_TX_IT) == I2C_XFER_TX_IT)
/* Disable TC and TXI interrupts */
tmpisr |= I2C_IT_TCI | I2C_IT_TXI;
if ((hi2c->State & HAL_I2C_STATE_LISTEN) != HAL_I2C_STATE_LISTEN)
/* Disable NACK and STOP interrupts */
tmpisr |= I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_ERRI;
if ((InterruptRequest & I2C_XFER_RX_IT) == I2C_XFER_RX_IT)
/* Disable TC and RXI interrupts */
tmpisr |= I2C_IT_TCI | I2C_IT_RXI;
if ((InterruptRequest & I2C_XFER_LISTEN_IT) == I2C_XFER_LISTEN_IT)
/* Disable ADDR, NACK and STOP interrupts */
tmpisr |= I2C_IT_ADDRI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_ERRI;
if ((InterruptRequest & I2C_XFER_ERROR_IT) == I2C_XFER_ERROR_IT)
/* Enable ERR and NACK interrupts */
tmpisr |= I2C_IT_ERRI | I2C_IT_NACKI;
if ((InterruptRequest & I2C_XFER_CPLT_IT) == I2C_XFER_CPLT_IT)
/* Enable STOP interrupts */
tmpisr |= I2C_IT_STOPI;
if ((InterruptRequest & I2C_XFER_RELOAD_IT) == I2C_XFER_RELOAD_IT)
/* Enable TC interrupts */
tmpisr |= I2C_IT_TCI;
/* Disable interrupts only at the end */
/* to avoid a breaking situation like at "t" time */
/* all disable interrupts request are not done */
__HAL_I2C_DISABLE_IT(hi2c, tmpisr);
return HAL_OK;
}I2C_Disable_IRQ is a import func in interrupt,but you could see the operation
the same code with the differnt means????
if any developer fix it or find somethings new here , please tell me :elmagnificogg@gmail.com,thank you
