STM32WB BLE
2024-05-28 12:35 AM
Hello ST,
For our project, I want to broadcast a character with property "CHAR_PROP_BROADCAST" and I created it using the function aci_gatt_add_char(). But the function fails to add this character.
In other case, when i change the property to "CHAR_PROP_READ", the character is added successfully.
Could you help me or provide me an example on how to broadcast a service using BROADCAST property ?
Thanks & Regards
Teja
- Labels:
STM32Cube MCU Packages
STM32CubeMX
2024-05-28 7:36 AM
Hello ST,
I was able to solve the problem. The error was in the service max_attributes _records. I forgot to add the client char configuration descriptor for the broadcast type.
But how can i test, whether the characteristic is broadcasting? I am using "aci_gatt_update_char_value()" this function for updating the characteristic value.
Please let me know, How this broadcast property of the character works or provide me an example ?
Teja
