STM32U5 + PWM + DMA
nicolas
Senior II
I'm able to generate a simple PWM signal but I wasn't able to generate arbitrary waveform with DMA (HAL_TIM_DMABurst_MultiWriteStart).
How should be configured the DMA ?
Is there an example that use PWM with DMA on STM32U5 ?
13 REPLIES 13
I have already tried this (__HAL_TIM_CLEAR_FLAG(&htim1, TIM_FLAG_UPDATE);) and it didn't help.
Hello @nicolas
Did you check the example below and compare with your code :
STM32CubeU0/Projects/NUCLEO-U083RC/Examples/TIM/TIM_DMABurst at main · STMicroelectronics/STM32CubeU0 · GitHub
Saket_Om
It doesn't help me because it use HAL_TIM_DMABurst_WriteStart() instead of HAL_TIM_DMABurst_MultiWriteStart() and the STM32U0 use DMA instead of GPDMA.
Looks like RCR and CCR1 are preloaded and my config was using an ARR not preloaded.
With a preloaded ARR, my ARR values doesn't need to be shifted.
htim.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
