Stm32h753 Azure-rtos USBX two USB device classes
2023-04-04 11:19 AM
My project uses stm32h753 and Azure (ThreadX and USBX), I want to have USBFS as CDC and USBHS for DFU. In CubeMX how do I specify which USB interface is for which device class, or it should be done in code?
AzureRTOS
STM32H7 Series
USB
2023-04-05 5:25 AM
Hi @XLin.2 ,
Device with more than 1 port is not allowed by the spec and not supported by USBx
Use composite device is the correct way to expose multi functionalities on a single USB port
2023-04-05 5:25 AM
Hi @XLin.2 ,
