benoit239955_stm1_st
stm32F4xx_hal_pcdm.c device generated by CUBE
  • March 23, 2016
  • 1 reply
  • 629 views
Posted on March 23, 2016 at 15:03
in the stm32F4xx_hal_pcdm.c source file,
in HAL_PCD_IRQHandler
the interrupt identified by USB_OTG_DIEPIN_XFRC is treated 2 times with the same code.
Is it necessary?
#hal-pcd-interrupt
1 reply
Nesrine M_O
Posted on March 23, 2016 at 17:03
Hi guibert.benoit,
What do you mean by the interrupt identified by USB_OTG_DIEPIN_XFRC is treated 2 times with the same code? Could you please provide more explanation?
Could you precise the CubeMX and the F4 HAL library versions are you using?
-Syrine-
