STM32F4discovery hight speed USB
its
Posted on November 30, 2012 at 05:15
Hi:
      I am using the USB part of  audio playback sample code of STM32F4 discovery. In waverecorder.c I customized the recorder_update() function. I think it stores data at the rate of 12Mbps in USB. M i right?
   I want to speed up the transfer rate. how is it possible?
thanks
#usb-storage-hs
Posted on November 30, 2012 at 12:40
You need an external PHY for High Speed USB. If it's not practical/desirable to add one consider a different eval board, I recall seeing some on eBay
its
Posted on December 03, 2012 at 05:54
thnks. I wanna ask in audio example it uses full speed... did it use 12Mbps or slower than that to store data in USB?
regards
