2015-04-26 10:11 PM
when I select USB_OTG_HS->extern phy->device only peripherals, I got warning:
These IPs still have some not configured or wrong parameter values?[Clock]Do you still want to generate code.what does this exactly mean? and how to solve it?I have doing somethin wrong with cubeMx?I have to configure some Clock manually in code?The IPs is not stable for use?ThanksSTM32CubeMX Version 4.7.0Fireware Package for Family STM32F2 1.1.1Chip: STM32F205RGTx #usb_otg_hs2015-04-26 10:36 PM
I've figured out that the clock have to be configured first.
Then, how to configure the clock with a extern phy usb?Is their any doc or note or tutorials?thanks2019-02-08 05:00 AM
i have the same problem someone help please?
