STM32Cube F2, LwIP, TCP UDP server example problem using RTOS
Posted on June 26, 2015 at 18:19
Hi:
I am trying the LwIP TCP/IP stack demonstration for STM32F2x7 microcontrollers based on LwIP TCP/IP stack and FreeRTOS on a STM3221G-EVAL board,(http://www.st.com/web/en/catalog/tools/FM147/CL1794/SC961/SS1743/LN1734/PF257896
), particularly the
UDP and TCP echo server application
described at the application note UM1713, and running the firmware under folder
LwIP_UDPTCP_Echo_Server_Netconn_RTOSsince I am using FreeRTOS.
I am running the echotool on a couples of PCs, but the firmware respond to only 1 PC at a time. When responding to echotool running on 1 PC, I am getting timeout responses on the other PC. Any ideas?
Thanks, #rtos #lwip #udp #tcp #echotool
