STM32 Touch Sensing Library Example Touchkey
Options
2016-05-11 4:02 PM
Posted on May 12, 2016 at 01:02
I am looking for any example of TouchKey application on any STM32 using Touch Sensing Library. Preferably using code generated by STM32CubeMX. Anyone? Any clue? Thank you.
#stm32-cube-touch-sensing-library
Labels:
STM32Cube MCU Packages
1 REPLY 1
Options
2016-05-12 1:12 AM
Posted on May 12, 2016 at 10:12
Hi susilo.ekawahyu,
Please note that TS is not yet supported in CubeMX. There is already a request raised in this regard.However you can refer to examples that you may find in the Cube package besides tohttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00210526.pdf
.Same topic already discussed [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/CUBEMX%20-%20code%20-%20add%20TSL%20Lib%20something%20is%20wrong¤tviews=51]here.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
