Stm32 FreeRtos Internal Flash Linker Script
ebast
I have some functions to read-and write to memory to STM32F103 internal memory. This functions work on the gcc and standard linker script. When I want to use the internal flash with stm32 and freertos. FreeRtos does not allow to me access when I want to write a data into internal flash. Here is the standard freertos linker script file.
Default linker script file for freertos for stm32.
* linker script for ST32F103 & MPU  REV 1.02
GROUP(libgcc.a libc.a)
MEMORY
    FLASH (rx)  : ORIGIN = 0x08000000, LENGTH = 1024K
    SRAM (xrw)  : ORIGIN = 0x20000000, LENGTH =  96K
/* Higher address of the user mode stack */
_estack = ORIGIN(SRAM)+LENGTH(SRAM);
 *There will be a link error if there is not this amount of RAM free at the end.
_Minimum_Stack_Size = 1K;
_Minimum_Heap_Size = 1K;
/* Variables used by FreeRTOS-MPU. */
_Privileged_Functions_Region_Size = 16K;
_Privileged_Data_Region_Size = 512;
__FLASH_segment_start__ = ORIGIN( FLASH );
__FLASH_segment_end__ = __FLASH_segment_start__ + LENGTH( FLASH );
__privileged_functions_start__ = ORIGIN( FLASH );
__privileged_functions_end__ = __privileged_functions_start__ + _Privileged_Functions_Region_Size;
__SRAM_segment_start__ = ORIGIN( SRAM );
__SRAM_segment_end__ = __SRAM_segment_start__ + LENGTH( SRAM );
__privileged_data_start__ = ORIGIN( SRAM );
__privileged_data_end__ = ORIGIN( SRAM ) + _Privileged_Data_Region_Size;
ENTRY(Reset_Handler)
SECTIONS
        Privileged section at the start of the flash.
        Vectors must be first whatever.
    .isr_vectors :
        . = ALIGN(4);
        _isr_vectors_offs = . - __FLASH_segment_start__;
        KEEP(*(.isr_vectors))            /* Startup code */
    } >FLASH
    privileged_functions :
        . = ALIGN(4);
        *(privileged_functions)
    } > FLASH
    /* Non privileged code starts here. */
    .text_offset :
        . = ALIGN(4);
        . =  . + _Privileged_Functions_Region_Size;
    } > FLASH
    .text :
        . = ALIGN(4);
        *(.text)                   /* remaining code */
        *(.text.*)                 /* remaining code */
        *(.rodata)                 /* read-only data (constants) */
        *(.rodata*)
        *(.glue_7)
        *(.glue_7t)
    } > FLASH
        .ARM.exidx is sorted, so has to go in its own output section.
    . = ALIGN(4);
    __exidx_start = .;
    .ARM.exidx :
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
    } >FLASH
    __exidx_end = .;
    .data.align :
        . = ALIGN(4);
        _etext = .;
        _sipdata = _etext; /* Used by the startup in order to initialize privileged variables */
    } >FLASH
    .pdata.align :
        . = ALIGN(4);
        . =  . + _Privileged_Data_Region_Size;
        _sidata = .; /* Used by the startup in order to initialize variables */
    } >FLASH
        * This is the Privileged data section. It is stored in RAM but the initial values
        * are held in flash and copied to RAM by the startup code
    privileged_data :  AT ( _sipdata )  /* AT makes the LMA follow on in the binary image */
        . = ALIGN(4);
        _bss = .;
        _spdata = . ;
        *(privileged_data)
        _epdata = . ;
    } > SRAM
        * This is the initialized data section. It is stored in RAM but the initial values
    .data_offset  :
        . = ALIGN(4);
    } > SRAM
    .data  : AT ( _sidata  )  /* AT makes the LMA follow on in the binary image */
        _sdata = . ; /* Used by the startup in order to initialize the .data section */
        KEEP(*(vtable))
        KEEP( *(.data) )
        KEEP( *(.data.*) )
        . = ALIGN(4);
        _edata = . ; /* Used by the startup in order to initialize the .data section */
    } >SRAM
        * This is the uninitialized data section. Date here is stored in RAM and will be
        * set to zero by the startup code.
    .bss :
        . = ALIGN(4);
        _sbss = .; /* Used by the startup in order to initialize the .bss section */
         *(.bss)
         *(.bss.*)
         *(COMMON)
        . = ALIGN(4);
        _ebss = . ; /* Used by the startup in order to initialize the .bss section */
    } >SRAM
 * This is the heap section
 * This is just to check that there is enough RAM left for the heap
 * It should generate an error if it's full.
    ._sheap :
        . = ALIGN(4);
      _heap_begin = . ;
      . = . + _Minimum_Heap_Size ;
      . = ALIGN(4);
      _heap_end = . ;
    } >SRAM
 * This is the user stack section
 * This is just to check that there is enough RAM left for the User mode stack
    ._usrstack :
        . = ALIGN(4);
      _susrstack = . ;
      . = . + _Minimum_Stack_Size ;
      . = ALIGN(4);
      _eusrstack = . ;
    } >SRAM
PROVIDE ( end = _ebss );
PROVIDE ( _end = _ebss );
PROVIDE( _heap = _heap_begin );
PROVIDE ( _eheap = _heap_end );
and here is the my new linker script file here to access the last page of the stm32f103 which is page 255. When I want to modify the page255. It does not allow me. Do you have suggestion that how can use the internal flash of the stm32 with freertos? I just need to use one page in the flash when freertos in the usage. Everything works if I do not use freertos
4 REPLIES 4
ebast
and here is the edited linker script file. The different between two linker script file. Thank you from now
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1022K
FLASH_STORAGE (rwx) : ORIGIN = 0x08000000+1022K, LENGTH = 2K
MEMORY
SECTIONS
    .isr_vectors :
        . = ALIGN(4);
    } >FLASH
        . = ALIGN(4);
    } > FLASH
    .text_offset :
        . = ALIGN(4);
    } > FLASH
    .text :
        . = ALIGN(4);
        *(.rodata*)
        *(.glue_7)
        *(.glue_7t)
    } > FLASH
    . = ALIGN(4);
    __exidx_start = .;
    .ARM.exidx :
    } >FLASH
    __exidx_end = .;
    .data.align :
        . = ALIGN(4);
        _etext = .;
    } >FLASH
    .pdata.align :
        . = ALIGN(4);
    } >FLASH
        . = ALIGN(4);
        _bss = .;
        _spdata = . ;
        *(privileged_data)
        _epdata = . ;
    } > SRAM
    .data_offset  :
        . = ALIGN(4);
    } > SRAM
        KEEP(*(vtable))
        KEEP( *(.data) )
        KEEP( *(.data.*) )
        . = ALIGN(4);
    } >SRAM
    .bss :
        . = ALIGN(4);
         *(.bss)
         *(.bss.*)
         *(COMMON)
        . = ALIGN(4);
    } >SRAM
    ._sheap :
        . = ALIGN(4);
      _heap_begin = . ;
      . = ALIGN(4);
      _heap_end = . ;
    } >SRAM
    ._usrstack :
        . = ALIGN(4);
      _susrstack = . ;
      . = ALIGN(4);
      _eusrstack = . ;
    } >SRAM
Check the MPU settings to understand what/why areas are protected from access
ebast
I will look that. You mean I will touch the linker script right?
No, something in your code is enabling and configuring the MPU with ranges of valid/usable addresses, review *that* code, once you understand what that is doing, and the expectation that creates pivot to how that gets described/controlled in the script.
Seem to recall the MPU wants regions which are a power of two. Check the TRM for the core.
