No UDP packets transmitted after ARP reply
2024-11-14 1:31 AM
I'm using the STM32F767ZITx MCU and the lwIP library to transmit and receive UDP packets every 1 ms.
Everything works fine but sometimes, after the ARP table has expired, UDP packets are no longer transmitted for several seconds even though my STM has received a response to its ARP request (as seen with Wireshark).
What solutions are there to avoid this scenario? Is this normal lwIP behavior?
Thanks for your help.
Ethernet
STM32F7 Series
2024-11-18 8:33 AM - edited 2024-11-18 8:34 AM
I was able to solve the problem.
Although I don't have a powerful enough tool to see the problem, I think that the ETH_REF_CLOCK signal (RMI only) used as a reference clock at 50MHz was not clean enough.
The clock was indeed at 50MHz but with another signal on it probably, because after a little filtering my problems disappeared.
Sorry to have involved you, thank you for your time.
- « Previous
- 1
- 2
- Next »
