2018-04-19 12:27 PM
If I buy a new STM32F303xC and solder it to my board, will it power up in DFU mode? Is it required to pull BOOT0 high to enter DFU mode? I would like to do first-time programming without manually using a jumper.
#new-unprogrammed-stm32f303xc-into-dfu-mode2018-04-19 02:54 PM
Have you read this document?
-- pa
2018-04-19 03:30 PM
Pretty sure the F3 will expect you to pull BOOT0 High to enter the System Loader
Or you could use SWD/JTAG if you've wired that up.
2018-04-20 08:56 AM
I figured as such. I'll have to add a jumper or button. After application code is loaded I will have the ability to enter DFU from the program.
