Mcbstm32c board ethernet problem
berat
Posted on April 25, 2015 at 11:15
Hi i have a MCBSTM32c board and i coudnot connect on my pc . i downloaded examples from st page . except the network examples, i tried  and it worked.  in the datasheet , it says make your ip static 192.168.0.1 and connect while realesed programs (for example ledswitch.exe) how can we communicate between the board and pc ?
#ethernet #stm32f107 #mcbstm32
Posted on April 25, 2015 at 11:53
Pretty sure all ST supplied examples target the EVAL series boards, not ones from Keil. You might have to port the code to deal with specific differences in the designs.
Are you using a cross-over cable, or connecting via a hub? Bit hard to decipher exact what you've done or how it's failing.
