Looking for Example Code for an MBEDTLS Client Application
paulrbryson
I have a specific question and a more general one.
  1. Specifically, is there example code from ST for a TLS client runnning MBEDTLS/LWIP on STM32?
  2. Generally, is there a repository somewhere for example code?
I see lots of references to example code, but for the life of me, I can not find it. Sometimes I find example code written by ST on github; but it was not posted by ST.
Guru
There are examples in the various CubeMX repositories on Github. For example:
https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Projects
6 REPLIES 6
Guru
Thank you very much! I have been Googling variations of "STM32 Example code" for weeks and browsing the ST web site and did not find this.
Piranha
Chief II
Also you can download it all in a single Cube packages.
https://www.st.com/en/embedded-software/stm32cubef2.html
And, as you are using CubeMX, you probably already have them in your computer. :)
Thanks, I did not know about the code coming from the CubeIDE. I was able to find it with a file search.
Is there a way to access this code from within the STM32CubeIDE? .. or some other easy way to find it's location?
I don't know why I had not found these repositories before.
They are at
C:\Users\username\STM32Cube\Repository
It seems that these repositories are not complete. They have the application code but not the underlying third party code.
Is this correct or am I missing something?
The problem is that the API's have changed and without the original third party code I have to guess what the example is trying to do.
