Is there any way to make CMSIS RTOS V1 integrate with CMSIS RTOS V2 in an application?
ZHaid.1
Then you can include both CMSIS RTOS v1 and V2 wrappers and make some files use V1 and some - V2, if you're careful.
Both wrappers will call the same FreeRTOS under the hood,
3 REPLIES 3
Pavel A.
Evangelist III
What is the actual RTOS below : RTX? FreeRTOS?
ZHaid.1
FreeRTOS
