How to update FATFS on STM32F103 Package ?
ABatt.1
Hi to all,
I need to update from FatFS from R0.11 to R0.12c
In R0.12c there are new implementations compared to 0.11.
I see that for the STM32F401 the FATFS is in version 0.12c.
Is there a way to update the library for the STM32F103 as well?
Thank you.
Both are still rather stale.
Older versions should be easy enough to substitute. Replace all the middleware files, and review the settings and match those up.
The newer version s (0.13 / 0.14) will take more effort to adjust the DISKIO layer.
Use a merge tool to understand the differences
ABatt.1
HI,
Thanks for your help.
substitute folder in repository works fine ( a part that Cube MX continue in use old ffconf.h, I need to update file every time I regenerate project in Cube MX).
Now I'm facing a hardFault every time was called function validate() in f_Write().
Other fuction works fine: I'm able to mount FAT and create a file.
This is independent of what versione of FATFS I use.
I'm investigating on why hardfault are generated. Someone have some suggestions?
