how to code STM32F4 SMBus manually ( without Cube HAL )
rsharifi9
Posted on September 04, 2017 at 09:56
dear All,
as we know there is not possible to configure and code STM32F4 SMBus with Cube HAL drivers.
is it possible to do that manually?
regards, Rasool
#smbus #stm32f4 #ll-drivers #cube-hal
Imen.D
Posted on September 04, 2017 at 10:23
Have a look to this
https://community.st.com/0D50X00009XkdjqSAB
, it may be helpful.
You may refer to the
http://www.st.com/content/ccc/resource/technical/document/reference_manual/3d/6d/5a/66/b4/99/40/d4/DM00031pdf/files/DM00031pdf/jcr:content/translations/en.DM00031pdf
reference manual for STM32F4
to have more details about SMBUS usage.
Best Regards
Imen
Imen
links are not available
Imen.D
Hello @KSzcz​ ,
You'll probably get help from the SMBUS examples within Cube firmware packages as:
 STM32Cube_FW_L0_V1.11.0\Projects\STM32L073Z_EVAL\Examples\SMBUS
 STM32Cube_FW_F3_V1.10.0\Projects\STM32303E_EVAL\Examples\SMBUS
The examples show how to ensure SMBUS Data buffer transmission and reception with IT.
 May be this link can help you:  https://github.com/Selat/stm32-smbus
Best Regards
Imen
Imen
