Hi i have an Nucleo-L073RZ eval board need to implement sd card +spi + fatfs on it, i have attached a microsd card slot to the eval board , using Sd card 16GB SDHC . I have referred many projects from online for STM32F0 board .
svii
It does not work on my eval board not even able to mount the sd card. Is their any restriction or limit wrt to clock for implementing this since stm32f0 can have max 0f 72MHz wheras stm32l0 only 32Mhz. if so how can this limitation be overcome . what else could be the problem .
0 REPLIES 0
